Ansys_ACT_Grouping
    • Stark
      Hi..,
      I have tried the scripting to group three named selections in a single group. But I am able to create a group with only one named selection. Is there a script to create a group with two or more named  selections. If so kindly share..,
      Thanks,
      Ackshai
    • Aniket
      This wouldn't come under standard support scope, but you can try something as below:
      objs = []
      for k in range(2): objs.append(Model.NamedSelections.Children[k])
      ExtAPI.DataModel.Tree.Group(objs)
      -Aniket
    • Stark
      Hii Aniket,
      I tried using the commands you have given. But it shows the following error.
      'Tree' object has no attribute 'Group'
      Is there any other way ?
      Thanks,
      Ackshai
    • Aniket
      Which version are you using?
    • Stark
      Ansys 18.2
    • Aniket
      I don't think this will work there you will need to upgrade to later version in order that to work.
Viewing 5 reply threads
