Ansys Products
Ansys Products
ANSYS_MESH_FM_ERROR_ID_CONVERT_WORKBENCH_TO_FLTG_ERROR
    • Gerard Bita
      Everytime i try to generate a surface mesh, the following error comes up and it does not allow me to procede.. i do not understand why, I also checked with the CAD Configuration manager but nothing.. does anyone know how to fix this problem? I uninstalled and reinstalled Ansys at least 4 times now and i have the same problem every time...
      n7    Home-PC   8/32  Windows-x64  15000  13th Gen Intel(R) Core(TM) i9-13900K
      n6    Home-PC   7/32  Windows-x64  9152   13th Gen Intel(R) Core(TM) i9-13900K
      n5    Home-PC   6/32  Windows-x64  11900  13th Gen Intel(R) Core(TM) i9-13900K
      n4    Home-PC   5/32  Windows-x64  14788  13th Gen Intel(R) Core(TM) i9-13900K
      n3    Home-PC   4/32  Windows-x64  14532  13th Gen Intel(R) Core(TM) i9-13900K
      n2    Home-PC   3/32  Windows-x64  15864  13th Gen Intel(R) Core(TM) i9-13900K
      n1    Home-PC   2/32  Windows-x64  17380  13th Gen Intel(R) Core(TM) i9-13900K
      n0*   Home-PC   1/32  Windows-x64  7320   13th Gen Intel(R) Core(TM) i9-13900K
      host  Home-PC         Windows-x64  5164   13th Gen Intel(R) Core(TM) i9-13900K
      MPI Option Selected: intel
      Selected system interconnect: default
      Cleanup script file is C:\Users\Gerard Bita\cleanup-fluent-Home-PC-5164.bat
      Meshing>
      Importing one geom object per program-controlled and one zone per body ...
          C:\Program Files\ANSYS Inc\v221\commonfiles\CPython\3_7\winx64\Release\python\..\Ansys\TGrid\CADReaders.py started by Gerard Bita on Home-PC winx64 on Wed Apr 19 15:17:53 2023
          using Python 3.7.11 (remotes/origin/b0b4eda9448d622fbb214539623a7f129f39e1f4-dirty:b0b4eda, Oct 18 20) [MSC v.1920 64 bit (AMD64)]
          using Ansys.Meshing.FieldMesher build Nov 30 2021 12:29:41 including TGLib build Nov 12 2019 13:13:16
          running ANSYS TGrid CADToTGridConverter ...
          setting up parameters ...
          setting up parameters done.
          running conversion ...
          converting 1 file(s) from Workbench to FLTG using output path '\\HOME-PC\Users\Gerard Bita\OneDrive - City, University of London\T2\T_files\dp0\FLTG\Fluent\FM_Home-PC_15132/out168191387315132.tgf'
          converting file 'Geom.agdb' (1 of 1) from Workbench to FLTG using output path '\\HOME-PC\Users\Gerard Bita\OneDrive - City, University of London\T2\T_files\dp0\FLTG\Fluent\FM_Home-PC_15132'
          importing data ...
          importing meshing model from PartMgr from file 'C:\Users\Gerard Bita\OneDrive - City, University of London\T2\T_files\dp0\Geom\DM\Geom.agdb' ...
          setting enclosure and symmetry processing to False
          setting transfer named selections to True
          setting named selection prefixes to ''
          setting mixed import resolution type to 'SolidAndSurface'
          setting target application to 'FluentMeshing'
          attaching to assembly ...
          attaching to assembly done in 10.986 [s]
          processing assembly 'C:\Users\Gerard Bita\OneDrive - City, University of London\T2\T_files\dp0\Geom\DM\Geom.agdb' with ID 1
          length unit = [m]
          processing part 'Air' with ID 3
          processing part 'Blade' with ID 5
          processing named selection 'Outlet'
          processing named selection 'Top_Inlet'
          processing named selection 'Inlet'
          processing named selection 'Periodic_1'
          processing named selection 'Periodic_2'
          processing data ...
          removing named collections of entities ...
          removing named collections of entities stopped, no named collections selected.
          analyzing feature edges ...
          detecting feature edges, feature angle = 40 [deg] ...
              Data information
                  Meshing model
                      Attributes:
                          'LengthUnit': '[m]'
                      Entity summary:
                          Collection: 5
                          Component : 3
                          Body      : 2
                          Shell     : 2
                          Face      : 9
                          Loop      : 9
                          Edge      : 17
                          Vertex    : 12
                          Surface   : 9
                          Curve     : 17
                      Tessellation summary:
                          Face facets  : 5276
                          Edge segments: 349
                      Bounding box:
                          (-23.90230178833008, 0, -27.60000038146973) x (23.90230178833008, 27.53276824951172, 55.20000076293945)
                      Assembly component hierarchy:
                            'Air'
                            'Blade'
                      NamedCollections:
                          'Outlet'
                          'Top_Inlet'
                          'Inlet'
                          'Periodic_1'
                          'Periodic_2'
          exporting FLTG data to file '\\HOME-PC\Users\Gerard Bita\OneDrive - City, University of London\T2\T_files\dp0\FLTG\Fluent\FM_Home-PC_15132\out168191387315132.tgf' ...
          writing face-based mesh file '\\HOME-PC\Users\Gerard Bita\OneDrive - City, University of London\T2\T_files\dp0\FLTG\Fluent\FM_Home-PC_15132\out168191387315132.tgf' ...
          ======== Exported Data ========
          Entity summary:
              Object       : 2
              Object region: 7
              Zone         : 16
          running conversion done.
          running ANSYS TGrid CADToTGridConverter done.
          ran ANSYS TGrid CADToTGridConverter in 11.162 [s]
      Reading "\HOME-PC\Users\Gerard Bita\OneDrive - City, University of London\T2\T_files\dp0\FLTG\Fluent\FM_Home-PC_15132/out168191387315132.tgf"...
      nodes: 2990
      edges: 238
      faces: 5276
      cells: 0
      reading 2990 storage data (id 1, type 41, double precision binary).
      generating pointers...done.
      extracting boundary entities...
       2990 boundary nodes.
       5276 boundary faces.
       6 boundary face zones.
      done.
      preparing mesh for display...done.
      analyzing boundary connectivity...done.
      ---------------- Import of Geom, consisting of 2 parts/objects, complete.
      Writing "C:\Users\Gerard Bita\OneDrive - City, University of London\T2\T_files\dp0\FLTG\Fluent\Workflow\TaskObject3.msh.h5" ...
      writing 1 node zones
      writing 10 edge zones
      writing 6 face zones
      done.
      Importing one mesh object per program-controlled and one zone per body ...
          C:\Program Files\ANSYS Inc\v221\commonfiles\CPython\3_7\winx64\Release\python\..\Ansys\TGrid\CADReaders.py started by Gerard Bita on Home-PC winx64 on Wed Apr 19 15:18:11 2023
          running ANSYS TGrid CADToTGridConverter FAILED! (file '\\HOME-PC\Users\Gerard Bita\OneDrive - City, University of London\T2\T_files\dp0\FLTG\Fluent\FM_Home-PC_15132\\' is not a directory.)
          ran ANSYS TGrid CADToTGridConverter in 0.009 [s]
              ======== Command Execution Log Manager ========
              Number of execution logs: 1
              DataTranslatorCommandExecLog
                  Label = 'ANSYS_MESH_FM_ERROR_ID_CONVERT_WORKBENCH_TO_FLTG_ERROR'
      Error: Error in CAD Import
      Error Object: #f
      Error: Error occurred during import.
      Error Object: #f
    • Federico Alzamora Previtali
      I suggest moving your geometry files to a different location than a OneDrive folder. Also, the path to the file should have no special characters or spaces.
      • Gerard Bita
        I found the problem, is because of the comma in the onedrive folder. thank you very much 🙂
