Platform
Platform
Ansysedt Command Line Options Changes from 2019
    • Borealis126
      Hi,In Ansys 2019 EM I used to use the commandnansysedt -features=beta -ng -runscriptandexit [script path] [.aedt path]nto run a script that would insert both a design and simulation, run the simulation, and extract the needed values. Note this is all being done on HPC.nAfter the upgrade to 2021, however, this no longer works. The - ng flag appears to no longer be compatible with - runscriptandexit (note that I am now also including - UseElectronicsPPE at the direction of our HPC team).nDo I need to switch to using some combination of batchextract/batchsolve/batchsave - and restructure my script - instead of runscriptandexit so I can continue to use the nongraphical mode? Or is there some quick fix to the above command line arguments that can be made?Thanks in advance!
Viewing 0 reply threads
