November 5, 2018 at 9:48 pm
debcrocker
SubscriberWe are new to running ansysedt on a SLURM-controlled system. Can someone get us information on getting this setup running? We've found a couple of places that talk about it from their user's point-of-view but it seems like not all the system setup is discussed.
November 7, 2018 at 7:07 pm
ANSYS_MMadore
Ansys EmployeeHello Deb,
I'll reach out to you directly with some additional information on this.
Thank you,
Matt
February 20, 2019 at 5:47 pm
digheum
SubscriberHello mmadore,
I am trying to run ANSYS WB and ANSYS EDT using RSM on a cluster that uses SLURM as the scheduler. I see that it is not a supported cluster but also noticed that there are customizations that can be made to the RSM xml files to make this work. That has not worked out so far. So, I have tried using a .sh file to try and use multiple nodes with multiple cores on each node. I can post the code and/or details of what steps I am using here if needed.
Could you provide some information on running distributed EDT on a SLURM system?
Thanks,
Umang
February 28, 2019 at 4:09 pm
tsiriaks
Ansys EmployeeHi Umang,
We will need to handle this out of the forum. Could you ask your professor or your ANSYS Support Coordinator of your school to contact ANSYS reps and reference this thread, for support ?
Thanks,
Win
- Maxwell, HFSS or Q3D?
- Error
2616
2098
1323
1110
461
