AnsysWB Module
    • JackieX
      Hi, everyone.
      I met a problem when I finish the calculation and choose the result visualization, it shows AnsysWB Module has stopped working. All my result is lost when I reopen Workbench. Would anyone give me some suggestions?
      Thank you so much!
    • Sandeep Medikonda
      Right click on Solution and Open Solver Files directory. Do you see a file.rst file there? If not, check if there is a folder _ProjectScratch folder in one of the parent directories. It is usually at the location where you can find _project_files
      If the rst file does exist and you are able to find it in windows explorer, you can then use Tools>Read Result Files in Mechanical to reload them.
    • JackieX
      Thank you so much for your reply. But there is no file in both folds you said.
