September 9, 2018 at 4:48 pm
September 9, 2018 at 4:49 pm
Sandeep Medikonda
Ansys EmployeeHi Kusharga,
Moved your post to a new discussion to help get faster responses.
September 10, 2018 at 9:32 am
Ansys EmployeeMoved to Geometry. I think your object is over 1000m long, either open in SpaceClaim or enable large body support (Units -> Large Body Support).
September 18, 2018 at 11:33 am
Kushagra_kant
SubscriberHey,
I get what you say but it doesn't matter about the length the model won't open because when I get out of the geometry the warning and error occurs even if i change the length or any other dimension of the product, because as soon as i get out of the geometry the update doesn't work.
September 19, 2018 at 4:42 pm
Ansys EmployeeCan you re-create the shape with more sensible dimensions? If you're reading from CAD check the export units.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2600
2088
1319
1108
459
