AnsysWBU.exe encountered a problem. A diagnostic file has been written: C:\Users\….\AppData\Local
    • Mn65
      Hello
      My laptop doesn't have enough speed to run ANSYS. So I asked my manager to give me another computer. they installed ANSYS on another computer and I'm trying to work remotely.
      I receive this error when I try to open my ANSYS model:
      AnsysWBU.exe encountered a problem. A diagnostic file has been written: C:\Users\....\AppData\Local\Temp\AnsysWBDumpFile.dmp.
      Do you think if I transfer my file to the computer the problem will be solved? Could you please help me to solve this problem?
    • Ashish Khemka
      Are you able to open the model on your laptop? Can you try transferring the file on the computer and see if the model opens? Generally, this message indicates a corrupted model. Please first check if the model opens up.
      Regards Ashish Khema
    • Mn65
      thank you for your response.
      yes it opens in my laptop I transferred the file to the computer but this error appears when I open the model. The geometry opens without problem. But the model no.
      regards
    • Ashish Khemka
      Can you try creating a new test model on the computer and see if it solves?
      Regards Ashish Khemka
    • Mn65
      Yes I tried it with a simpler model. It shows the same error when I try to open the model.
    • Ashish Khemka
      This might be an installation issue.
    • Mn65
      Thank you very much.
      I will tell the admin to reinstall it again
Viewing 6 reply threads
