May 6, 2019 at 8:06 am
Surendrasg1
SubscriberI have suffered from this problem. Please suggest me. I am using Ansys 19.1 in windows 10 64 bit
May 7, 2019 at 9:24 am
Ansys EmployeePlease can you post more details? What were you doing when you got the error? Remember to post images into the text window: staff can't open attachments.
October 24, 2019 at 9:29 am
October 24, 2019 at 9:31 am
October 24, 2019 at 10:35 am
Ansys EmployeeOK, so the problem could be in the geometry: what does it look like? It's also possible to corrupt the workflows, if that's happened drag another workflow into Workbench and connect the geometry from the first to the second.
October 24, 2019 at 11:30 am
October 24, 2019 at 12:29 pm
Ansys EmployeeOK, open DesignModeler and check the geometry: what changed?
October 25, 2019 at 5:43 am
Surendrasg1
SubscriberDuring analysis, sometimes it is necessary to change in geometry. I have change in geometry in Design Modeler. It is now checked (OK). But while opening the Model, the problem is encountered in attachment of geometry. You can see the screen shots.
October 25, 2019 at 10:46 am
Ansys EmployeeRight, so what happens if you connect to a new workflow Model? Knowing what changed is also useful, have you gained/lost any named selections, faces or volumes?
October 25, 2019 at 10:57 am
Surendrasg1
SubscriberNow i am doing it by closing Ansys, then re-open it again and again around 10/12 times. It takes around half to one hour. I want refreshing revised geometry without any problem.
October 25, 2019 at 1:42 pm
Ansys EmployeeAnd what about when you connect to a new Model component?
October 25, 2019 at 3:54 pm
November 18, 2019 at 8:14 am
Surendrasg1
SubscriberThank you for Reply. I am also suffering from it.
November 17, 2020 at 12:41 pm
daanush
Subscriberi got the same error. i tried what ever i could from the web ,still not resolved.nn
Simulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
- Command Object Snippet
- Errors – Reinforced Concrete Beam
- Massive amount of memory (RAM) required for solve
- Large deflection
- Transient Structural analysis?
- Revolute joint (Static structural) Very high deformation
613
560
220
188
128
© 2022 Copyright ANSYS, Inc. All rights reserved.
