November 24, 2017 at 10:24 pm
leklaryba
SubscriberGot this message while running Ansys 18.2 Students version:
AnsysWBU.exe encountered a problem. A diagnostic file has been written: ..../AppData/Local/Temp/AnsysWBDumpFile.dmp
I'm not able to perform anything, meshing, solving, nothing. Design Modeler works. I tried to update graphics, reinstall, delete registers, reinstall again, something with system variables, but nothing wokrs.
Can you help me? Thank you very much
November 26, 2017 at 1:27 pm
SubscriberIt sounds like you have done everything suggested here.
Do you mean that ANSYS Student 18.2 once worked properly, then it stopped working?
If it once worked, one idea is to format the C: drive and make a clean install of Windows. I know that is a lot of work but it should result in a working version of ANSYS to your system again.
November 26, 2017 at 8:28 pm
leklaryba
SubscriberHi, it never worked before, this is the first try, in the meantime, i installed 18.1 and it wokrs
December 28, 2020 at 7:45 am
amit_yadav
Subscriberwhile doing mechanical meshing after giving geometry in my ansys workbench2020 its not working and pup up message that AnsysWBU.exe encountered a problem and diagnostic file has been written on c. drive.. before commenting here i follow all the instruction provided here i moved exe to old ,also i changed the name from v202 to v202.old but still it encountered the same problem. below is the screenshot of my problem.nplease help me with the solution.nn
March 8, 2021 at 4:54 am
Farhana1234
SubscriberI am facing same problem. Did you solve it? if yes , what is the procedures? nThanksn
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2600
2088
1319
1108
459
