Ansys Products
Ansys Products
AnsysWBU.exe error – Unable to mesh
    • navs0001
      I am unable to mesh part in ANSYS R20. Every time I click generate mesh, I get an error "AnsysWBU.exe encountered a problem. A diagnostic file has been written" and the meshing window closes automatically. However, I don't get any errors while meshing in Ansys R19.2.
      So far I have tried the following:
      1. Updating to latest Graphics Drivers and also tried older version drivers (graphics card is  Quadro RTX 4000)
      2. Updating Windows
      3. Stopped Windows Firewall
      4. Manually Installing Prereq
      5. Adding system environment variable: FLUENT_LAUNCHER_OPTIONS = -driver opengl
      6. Manually Registering dll files in CMD prompt
      7. Renaming App data folder
      I also analyzed the DMP file and got the following message,
      "In AnsysWBDumpFile.dmp the module C:WindowsMicrosoft.NETFramework64v4.0.30319clr.dll has caused an access violation exception (0xC0000005) when trying to read from memory location 0x00000008 on thread "
      Thanks for any help.
      Regards
    • navs0001
      PC specs
      PC specs
    • tsiriaks
      Thank you for searching past posts and list everything you have tried , this is great !!
      For the graphics driver of your RTX 4000, can you try this one
      https://www.nvidia.com/Download/driverResults.aspx/159681/en-us
    • navs0001
      I did try this 442.92 version as well as other versions of the drivers just to check if any of the version works. But no luck!! : (
      DMP analysis looks the same.
    • navs0001
      Hi again,
      I installed Ansys 19R1 & 19R3. Both of these versions worked just fine.
      However, the latest version 20R1 still doesn't work!
      Can anyone please help me out? I need to use 20R1 for uni work.
    • tsiriaks
      Check your 'Programs and Features' to see all of the MSVC++ versions and builds installed on your machine. Then check that against what ANSYS has in the prerequisites folder (you can check each installer 'Properties' to see its build version)
      There might be something else on the machine that installed some other build version and that one interferes with the one ANSYS needs to use.
    • navs0001
      Thanks for the reply.
      I deleted all the versions of MSVC++ from the pc and installed new ones from ANSYS prereq folder. But still no luck. : /
      Don't know why I am getting this error only in 20R1 when 19R1 & 19R3 work just fine!
    • tsiriaks
      Open CMD Prompt, then enter this command
      reg query "HKEY_LOCAL_MACHINESOFTWAREMicrosoftNET Framework SetupNDPv4Full" /v Release
      and post the output of it here
      Also, post the output of
      set
      command
    • navs0001
    • navs0001
    • tsiriaks
      Do you have an install.err file under C:Program FilesANSYS Inc
      What was the name of the installation package that you used for 2020 R1 ?
      What is the output of this command from CMD Prompt
      "%awp_root201%..Shared FilesLicensingwinx64ansysli_util" -checkout ANS_MESH
Viewing 10 reply threads
