August 30, 2018 at 3:18 pm
andreev
SubscriberHi,
I have created an antenna array (4 radiators) and calculated an radiation pattern of that array. However, the calculated radiation pattern looks like a radiation pattern produced by a single antenna, not an array of four antennae. So, I wonder, what is wrong with my simulations? The input file is attached.
Thanks!
August 30, 2018 at 8:21 pm
August 30, 2018 at 8:41 pm
Peter Serano
Ansys EmployeeCheck the Source Excitation Settings found under "HFSS > Fields > Edit Sources". By default only the first port is excited.
August 30, 2018 at 10:48 pm
andreev
SubscriberPeter, thank you!
It works!
August 31, 2018 at 2:22 pm
Peter Serano
Ansys EmployeeYou're welcome! Can you please 'like' and tag my post as the answer to your question? Thanks!
- Maxwell, HFSS or Q3D?
- Error
2706
2142
1355
1144
462
