Ansys Products
Ansys Products
Antenna efficiency calculations
    • vinay91
      I have some planar antennas on a IC substrate and would like to look at the radiated power broadside vs that which is sent into the substrate and radiates out the back. I tried using two infinite sphere radiation boundaries - one covering the upper hemisphere, and one covering the lower hemisphere. (My antenna feed is at 0,0,0 and suspened on a substrate that extends in the -z direction).
      The first hemisphere extends from phi:-180 to 180, theta:0 to 90
      The second hemisphere extends from phi:-180 to 180, theta:90 to 180
      I have a PML boundary around the entire antenna.
      I get exactly the same values of all the antenna parameters (except front to back ratio) for both cases. Could someone please explain where I am going wrong?
    • tsiriaks
      Please post your question in a correct section to get proper responses.
      For this question, post it in here
    • vinay91
      Thank you, I just did.
      Thank you, I'll lock this thread to avoid any duplication of effort.
Viewing 3 reply threads
