Electronics & Electromagnetics
Antenna – return loss
    • VivekKamble
      I have designed a patch antenna, but my return loss is not good, how can I improve return loss? Any suggestions
    • Charlotte Blair
      Hi @"Vivek Kamble" ,
      For this you have to check the antenna design, and go for changing feedline width as well as patch dimensions.
      Hope that helps!
    • VivekKamble
      Thanks for your quick response.
    • rtk
        Hi, addition to the above answer, the feed line width determines the characteristics impedance.
Viewing 3 reply threads
