January 29, 2022 at 7:42 pm
Sardar
SubscriberA rotary domain containing an impeller is inside a stationary one, all configured for sliding mesh method. The entire domain is to be meshed via ANSYS meshing. Should the mesh size for the rotary domain be different than that of the stationary one? Is it right to mesh the rotary coarser because the fluid adjacent to the rotor is going to move at higher velocities, hence larger/coarser cells are needed to capture fluid specifications in a given time step.
I know there are other factors influencing cell size, like higher accuracy I might be interested in across a given area of my domain requiring finer mesh, and so on. However, what if I am not interested in any specific feature for any specific area of my domain? Should I mesh the rotary finer or coarser given the fluid velocity near the rotor?
Thanks
January 31, 2022 at 10:20 amKeyur Kanade
Ansys EmployeeViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- how to improve the inflation quality at sharp corners?
- check element type
- Meshing Error
- How to resolve Mesh Failure
- Error in meshing
3930
2649
1861
1272
610
