October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeAny suggestions on speeding up convergence behavior with surface-to-surface radiation?
October 17, 2017 at 9:11 am
cbhavsar
Ansys EmployeeHere are some checks that can be useful to speedup convergence 1. If the initial temp of parts/regions close to the final temperature, it can decrease total # of iterations. (For Mechanical, the initial temperature can only be defined for the entire system, not per part. Either link another analysis where you solve a trivial condition of temp=X for part Y to be used as initial temperatures, or use a "Commands (APDL)" object with IC commands. 2. Tighten the radiosity solver tolerance. This may sound unintuitive, but the tighter the tolerance, the more accurate the heat fluxes that are passed back to MAPDL, meaning that you have fewer total iterations. 3. Try changing over-relaxation factor to 0.5. The radiative flux over-relaxation value uses a portion of the previous solution. The default is 0.1, which makes convergence slow since 90% of the previous solution is used. Since you have a radiation-dominant problem (i.e., only heat flow path between two bodies is via radiation), you probably don't want to set it to 1.0 (use only currently-calculated values and not previous solution), but using a higher value than the default of 0.1 can help reduce total number of iterations. It is advised to try each of these things, one at a time, to see which option has the biggest (positive) effect for particular case rather than changing all 3 at once.
March 27, 2018 at 7:32 am
cbhavsar
Ansys Employeetesting1
March 27, 2018 at 7:33 am
cbhavsar
Ansys Employee -
cbhavsar
Ansys Employee -
March 27, 2018 at 7:34 am
cbhavsar
Ansys Employeetesting11
March 27, 2018 at 7:35 am
cbhavsar
Ansys Employeetesting2
- How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
- Can I define springs with coincident nodes defining each end? Can I use one spring element to define
- Check
- If SCDM issues the message “Cannot open the document. Reason: Failed to load body geometry.” and the
- Any suggestions on speeding up convergence behavior with surface-to-surface radiation?
- What is cause of error: display time for result item greater than the step end time?
- In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
- While projecting surfaces/curves onto cylindrical surfaces, the final shape sometimes deteriorates.
- How can I do a response spectrum analysis using more than 10,000 modes? The current solver limit is
- Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane windo
2610
2088
1319
1108
459
