Anyone saw this “offending pire” warning message before?
    • MHZ
      "The work load is highly imbalanced for this Distributed ANSYS solution, due to the contact elements in (Frictional - CONTACT_A To CONTACT_B). This will negatively impact the scaling at higher core counts. You may select the offending pair via RMB on this warning in the Messages window."
      Hello All,
      The above is the error message. it is a steady analysis with multiple steps load. But it is extremely slow running on a HPC. Can anyone give some suggestions regarding the "offending pair"? I did not any helpful information with google and searching on this forum.
      Thanks,
      MHZ
    • 1shan
      Could you insert inline images of your model (showing the offending contact) to support your query. Also check the initial contact status and see if the offending pair is closed and touching at start of simulation.
      Regards Ishan.
