June 1, 2023 at 6:12 am
Andres Felipe Valencia
SubscriberHello everyone, cardiologist here just starting with 3D modeling. I am using Ansys discovery and I am trying to manipulate the sketch plane to be on a very precise position in the Aortic valve entry, so far with no success. I was wondering if there is any way to give to the sketch plane an exact numeric tilt angle input and position on the given geometry. Thanks
June 1, 2023 at 8:15 am
June 2, 2023 at 8:19 pm
SubscriberThank you Ashish, your response was very helpfull. Do you know where could I find further documentation for this kind of "basic" use and manipulation of the sketch axis.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7742
4502
2961
1449
1322
