    • Ailton777
      how can I delete all error file mensajes in APDL?
    • Aniket
      Please explain your question in more detail. Specifically, what is the motive of this? Also. please make sure that you insert the images (if any) inline as Ansys staff can not download attachments from the student community.
      -Aniket
    • Ailton777
      Thank you for your contact.
      when doing a new thermal analysis, there is already a list of errors with several topics before starting to run the script; probably from previous analizes. I don't know how to fix this.
      LISTA DE ERROS
      /COM,ANSYS RELEASE Release 16.0      BUILD 16.0      UP20141203       14:14:02
       *** WARNING ***                         CP =      16.250   TIME= 14:15:12
       /CONFIG is not a recognized PREP7 command, abbreviation, or macro.
        This command will be ignored.
       Material property table exceeds the number of defined temperatures.
        Number of temperatures is 13.  The number of data values is 14.
       *** WARNING ***                         CP =      19.359   TIME= 14:15:16
       All of the selected volumes in the set named on the VMESH command were
       already meshed.  Clear associated elements before remeshing.
       *** WARNING ***                         CP =      85.094   TIME= 14:16:17
       An inactive degree of freedom label (UX) was found on the D command.
       The current degree of freedom set is: TEMP
        This degree of freedom will be ignored.
       An inactive degree of freedom label (UY) was found on the D command.
       An inactive degree of freedom label (UZ) was found on the D command.
       No valid degree of freedom labels were input.  The D command is
       ignored.
       *** WARNING ***                         CP =      85.109   TIME= 14:16:17
       ignored.
       *** WARNING ***                         CP =      85.156   TIME= 14:16:17
       ignored.
       *** WARNING ***                         CP =      85.203   TIME= 14:16:17
       ignored.
       *** WARNING ***                         CP =      85.297   TIME= 14:16:17
       The NODAL LOAD label of FY is not part of the currently active set.
        The current NODAL LOAD set is: HEAT .
       *** WARNING ***                         CP =     119.422   TIME= 14:16:40
       Entity 10000004 is undefined.  The NSEL command is ignored.
       *** WARNING ***                         CP =     303.312   TIME= 14:190
       Material property KXX of material 1 of element 1 is evaluated at a
       temperature of 5.29357924, which is below the supplied temperature
       range.  Temperature range checking terminates.
      0***** process error reported by subroutine   xdslfa
             see    xdslfa abstract (ier =  -598)
       *** ERROR ***                           CP =   25287.547   TIME= 20:22:04
       The Sparse Matrix solver was aborted by jobname.abt or the STOP button
       was pressed.
      /COM,ANSYS RELEASE Release 16.0      BUILD 16.0      UP20141203       22:44:29
       *** WARNING ***                         CP =      13.234   TIME= 22:45:07
       *** WARNING ***                         CP =      13.250   TIME= 22:45:07
       Entity 1 is undefined.  The MPDELE command is ignored.
       *** WARNING ***                         CP =      13.266   TIME= 22:45:07
       *** WARNING ***                         CP =     534.609   TIME= 22:53:20
       Material property KXX of material 1 of element 16 is evaluated at a
       temperature of 13.2156091, which is below the supplied temperature
       *** WARNING ***                         CP =   60761.141   TIME= 12:55:00
       The view for graph plots is currently NOT changeable.
        To enable graph view manipulation, issue /GROPTS,VIEW,1.
       *** WARNING ***                         CP =   60761.156   TIME= 12:55:05
       *** WARNING ***                         CP =   60761.172   TIME= 12:55:06
       *** WARNING ***                         CP =   60761.188   TIME= 12:55:10
       *** WARNING ***                         CP =   60761.203   TIME= 12:55:11
       *** WARNING ***                         CP =   60761.219   TIME= 12:55:12
       *** WARNING ***                         CP =   60761.234   TIME= 12:55:14
      Aniket
      There are numerous warnings and only one error. The error indicates that you have stopped the analysis by clicking on the stop button.
      -Aniket
    • Ailton777
      Thank you.
      I understood; my notebook was with hibernate active.
Viewing 4 reply threads
