June 2, 2023 at 8:34 am
June 5, 2023 at 2:51 pm
Chris Quan
Ansys EmployeeBoth APDL commands in your post are related to ANSYS LS-DYNA in MAPDL GUI. ANSYS LS-DYNA is no longer available in MAPDL GUI. All of its functionalities have been migrated into LS-DYNA system in Workbench.
Furthermore, WB LS-DYNA system contains more LS-DYNA material models and many other LS-DYNA capabilities than ANSYS LS-DYNA in MAPDL GUI.
If you want to create a new ANSYS LS-DYNA model, I will suggest you using WB LS-DYNA system.
If you have LS-DYNA K files created from the previous releases, you can using External Model system in Workbench to read these K files and then transfer them to WB LS-DYNA system.
- Explicit dynamics ERRORS
- explicit dynamics
- turning simulation
- Monte Carlo Simulation
- How to solve Energy error too large
7690
4476
2957
1435
1322
