APDL element and geometry associativity
    • Rashi
      Hi all,
      I have generated a 3d mesh in APDL by rotating a meshed cross-section in APDL. The issue is the generated volume does not have a volume number. Also, when I select a face in the new volume and try to select the elements associated with the area APDL does to give any elements selected.
      I want to know how can I keep the associativity with the new 3d mesh and 3d volume?
      Thanks.
      Best regards,
      Rashiga
    • jj77
      Can you explain more. You say you have a mesh by rotating a 2D mesh? To generate a 2D mesh one meshes an AREA (AMESH), not a volume. So where does the volume come in - explain the steps you take and what you get and what is missing.
    • Rashi
      jj77,
      Thank you for your reply.  Yes, I used "AMESH" to mesh the 2d surface and used "VROTAT" to mesh rotate the 2d mesh into a 3d mesh. But when I use "VPLOT" I can see a volume.
