June 30, 2019 at 9:52 am
Noelly
SubscriberHello,
I'm trying to find the average stress value on a face in Static Structural (the maximum value is the design criterion but for this application, I also need to report the average value). I've never used APDL before so I found this code online for a command:
! Commands inserted into this file will be executed immediately after the ANSYS /POST1 command.
! Active UNIT system in Workbench when this object was created: U.S. Customary (in, lbm, lbf, s, V, A)
! NOTE: Any data that requires units (such as mass) is assumed to be in the consistent solver unit system.
! See Solving Units in the help system for more information.
/post1
allsel,all
set,last ! Read result set
cmsel,s,face_01,node ! Select the node group
Atot=0.0 ! Reset total area value.
tot_stress=0.0 ! Reset total volume times stress value.
*GET,NNUM,NODE,0,COUNT ! Get total number of nodes in the name selection
ncounter = 0 ! Node number counter reset to zero
*DO,I,1,NNUM,1 ! Loop over all the selected nodes
ncounter = ndnext(ncounter) ! Acess the next node in the selection
narea = arnode(ncounter) ! Calculate the area associated with this node
*GET,vonmises,NODE,ncounter,s,EQV ! Calculate the stress at this node.
tot_stress = tot_stress + narea*vonmises
Atot = narea + Atot
*ENDDO
my_avestress1=tot_stress/Atot ! Calculate average stress.
fini
And I defined the face of interest as "face_01":
But there is no solution... I think the problem is to access the result set but I don't know why it does not work.
I also tried using the probe but it does not give average values.
3744
2573
1821
1236
594
