November 26, 2017 at 9:04 pm
amr_0711
SubscriberDear Ansys Community,
how can I import a geometry file ( .txt file with #node x y z coordinates)?
It should work on Preprocessor / Modeling / Create / Nodes / Read Node File
I did an export ("write node file") to see, how apdl would like to get the information, but the import the other way round with added nodes doesn't work at all..what could my mistake be? I edited it with text editor and a ascii editor...
August 28, 2019 at 9:17 am
sampathkumar23
SubscriberHave you find any answer for your question?
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2616
2098
1323
1108
461
