December 8, 2021 at 10:18 am
Clemens_C
SubscriberI did a mode-superposition transient analysis with a cantilever. In /post26 I can get the displacement of nodes (with NSOL,,,U, Y), which is nice.
But I also need the nodal acceleration. Unfortunately I don't have access to that data. I don't understand why, because I set (VAout=YES) in TRNOPT. I tried a few options with the OUTRES command:
OUTRES,ALL,ALL or OUTRES,NSOL,ALL or OUTRES,A,ALL
But nothing works when I try the command NSOL,,,ACC,Y. :(
December 10, 2021 at 1:54 pmRahul Kumbhar
Ansys EmployeePlease try adding SET,.. command before NSOL command.
December 10, 2021 at 2:07 pmClemens_C
Subscriberthank you for message. It doesn't work. I still get the message: "The label ACC cannot be used, as the data is not avaiable. Please check the TRNOPT command (VAout) as well as the expansion pass OUTRES command. The NSOL command is ignored."
To get the acceleration I used the DERIV command.
December 10, 2021 at 3:55 pmAshish Khemka
Nodal velocity and acceleration are only written to the results file for a full transient and not an MSUP transient. You can use DERIV command for getting the acceleration.
Regards Ashish Khemka
December 10, 2021 at 6:24 pmClemens_C
SubscriberThank you a lot! But I'm very confused. Why does it say "The mode-superposition transient solution (the modal coordinates) is written to the reduced displacement file,Jobname.rdsp,[...]. Only the displacement, velocity, and acceleration solutions can be post-processed directly in POST26" in 5.4.3.1. Obtaining the Solution???
So why is the acceleration not available?
Regards Clemens
March 9, 2022 at 9:56 ammaimang
SubscriberBy default in a mode-superposition transient analysis, reaction force and other force output contains only static contributions. If you want to postprocess the velocities, accelerations, and derived results (Lab = TOTAL, DAMP, or INERT on the FORCE command), set VAout = YES to activate velocity and acceleration output.
Viewing 5 reply threads- You must be logged in to reply to this topic.
2508
2064
1277
1088
456
