January 17, 2023 at 10:41 am
Saad Sultan
SubscriberHello Everyone,
I have a lot of .mac files from the previous projects. Is there any way or method which can enable a line-by-line debugging of the macros ?
Just like debugging a code written in a programming language where the programmer can see the variables stored during run-time.
best regards,
January 17, 2023 at 4:07 pm
Dave Looman
Ansys EmployeeThere is an undocumented command, DEBUG, you can issue in the APDL gui. After issuing the command input the macro and you can step through it line by line.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
457
