October 27, 2018 at 6:21 pm
ebone2god
SubscriberHello,
I'm having an issue running a simulation in APDL. I am reading an input from a .txt file to run a quasi-static simulation named "AllRuns" and output the results to a new .txt file. When the solution completes and tries to write the outputs to a text file, I get an error message stating:
"Load Set not found on results file AllRuns.rst"
I'm following the same steps as I followed a few days ago to run this simulation, but this is the first time I have seen this error and I can't seem to solve it. Has anybody encountered this issue before? I would appreciate any suggestions on how to fix this problem.
Best regards,
Eoghan
2120
1349
1118
461
