APDL reduced model
    • HossamGhazal
      Hello
      Please,I need help.I would like to ask about the below error messege which appeared to me during my simulation..... as I recived a model and I would like to reduce it to get simplifed mass and stiffnes matrices which I can use it in matlab....I used my code for small models(by using generation pass by CMS method) and it works but for the real model, I have this error which I can not understand it....any idea please
      This error messge is contradicted foe the plot list data and my input as I put all my master DOF nodes
      No MASTER degrees of freedom are specified.  If the TOTAL command was used for automatic generation of MASTER degrees of freedom, it is invalid with the SPARSE solver in a substructure analysis.  Please use the M command to define at least one MASTER degree of freedom.
      ALL BOUNDARY CONDITION DISPLAY KEYS SET TO  1
      Thanks
    • sk_cheah
      The error message seems to say you don't have any master DOF specified. See this doc: https://web.engr.uky.edu/~jbaker/ANSYS-Stiffness_Matrix-v8p1.pdf
    • HossamGhazal
      Hello
      Thanks for reply
      But I had already put my master degree of freedom with same commands as you send it in your pdf and the solution options window also confirms that I select the master nodes with the total DOF as they are 6 master nodes with 36 DOF. However,I am reciving this error message as I am not selecting any master nodes.....
      Model comands
      then CMS commands:
      /solu
      antype, substr
      CMSOPT, FIX, 10, , , , , TCMS
              SEOPT, CMS123, 2, 1, 0
              OUTPR,ALL,ALL
      csys,0
      cmsel,s,ELEMENTS_LP
      nsel,s,,,Node_Load_1
      nsel,a,,,Node_Load_2
      nsel,a,,,Node_Load_3
      nsel,a,,,Node_Load_4
      nsel,a,,,Node_Load_5
      nsel,a,,,Node_Load_6
              m,all,all
      allsel
      /output,gh
      solve
      /output
      Also the solution options command :
                             S O L U T I O N   O P T I O N S
         PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D
         DEGREES OF FREEDOM. . . . . . UX   UY   UZ   ROTX ROTY ROTZ
         ANALYSIS TYPE . . . . . . . . . . . . . . . . .SUBSTRUCTURE
          SUPERELEMENT FILE NAME . . . . . . . . . . .CMS123
         OFFSET TEMPERATURE FROM ABSOLUTE ZERO . . . . .  273.15
         MATRICES TO GENERATE. . . . . . . . . . . . . .K AND M
         SUPERELEMENT PRINT OPTIONS. . . . . . . . . . .PRINT ALL
         STRESS STIFFNESS MATRIX SPACE KEY . . . . . . .OFF
         NUMBER OF MASTER DOF. . . . . . . . . . . . . .    36
         GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .SYMMETRIC
      Then I recived this error.
       *** ERROR ***
      Any idea please as I am really confusing and I am stucked at this point
      Thanks
    • sk_cheah
      I'm not sure what could be the cause of that. Perhaps your license doesn't allow for CMS? Sorry, I'm not much help.
    • HossamGhazal
      I think I realized the problem is due to that I am selecting my master nodes for my reduced model as the same master nodes for the MPC body but I do not know how to fix this problem as when I selected other random nodes as my master nodes ....it works normaly and the reduced matrices are created.
      I am trying now to fiqure out how can I select the master nodes of MPC as the same master nodes for reduced model
      Thanks alot
    • sk_cheah
      Try create MASS21 with node coincident with the MPC nodes. Join each pair nodes using COMBIN14 with keyopt(2)= 1, 2, 3 respectively and have a very high stiffness. Next, define the MASS21 nodes as master nodes.
    • KDakhili
      Hi,nDo you know how we should select master DOFs when we only want to select one of the DOFs per node, not all of them?n
    • Mathilde31
      I have exactly the same problem with model reduction using Workbench (error: No MASTER degrees of freedom are specified.  If the TOTAL command was used for automatic generation of MASTER degrees of freedom, it is invalid with the SPARSE solver in a substructure analysis.  Please use  the M command to define at least one MASTER degree of freedom.).
      Someone managed to find a solution ?
Viewing 7 reply threads
