August 29, 2022 at 8:36 pm
mlanahan3
SubscriberDuring the Structural Tutorial in the "Introductory Tutorials" for APDL, when I try to select the option "Add/Edit/Delete" from the Element Type drop down (Main Menu > Preprocessor > Element Type > Add/Edit/Delete) the expected dialog box does not appear. Moreover, after clicking this item I am unable to select anything else in the APDL GUI until I force quit the application and restart.
How do I resolve this issue so that I can view the expected dialog box, allowing me to add element types and complete the tutorial?
Thanks,
Mike
August 30, 2022 at 1:17 pm
Erik Kostson
Ansys EmployeeThat has been noticed (apdl ui given issues).
I would therefor suggest to use it via input files/commands and not from the UI.
E.g., to define elements use ET command, etc. All fo the commands can be found in our command reference manual.
Also there are many input file examples in our help which can be used to learn the command/design language that APDL uses.
All the best
Erik
August 30, 2022 at 3:52 pm
August 30, 2022 at 7:21 pm
mlanahan3
SubscriberErik,
At the moment I'm just following the introductory tutorials and don't want to complicate things. I'll investigate using textual commands in the future.
Mike, your suggestion worked. Thanks for the help!
Mike
2120
1347
1118
461
