APDL Transient Analysis Only Registering 1st Acceleration Step
    • louis2222
      Hi there, I am having some trouble in ANSYS!
      Short story: I am struggling to get transient analysis load steps (in the form of acceleration) to work. Please could you have a look at my code and let me know if something is obviously wrong? It is only reading the first acceleration step for the x axis, then applying it to both x and y, and then staying at a constant acceleration after that.
      Long story: I am trying to carry out transient analysis on a 3 story structure using acceleration data (gathered experimentally) to excite the structure at its base. The structure is mounted on an xy axis shaking table to simulate earthquakes (so I am assuming it is only constrained in the z direction at the base, as well as within the xy limits of the table). I am importing the acceleration data into a table, and then using a do loop to read the accelerations at each point to complete the transient analysis, as you can see in my code below. The problem I have is that ANSYS is only applying the 1st acceleration step. The remaining analysis is just for free oscillation. You can see this in the photo attached in the "Bot_Y_ACCEL" line. It moves to the first load step (in this case 0.5), then stays there. The rest of the lines just oscillate about this straight line. This is just impulse response, however I need to analyse sustained and varying accelerations!
      Any help at all would be so appreciated and you might just save my master's project. Many thanks in advance!
      /FILENAME,Transient_Test
      /SOLU
      FILE = 'data' !Enter data file name
      DT=0.00781 !Time interval (1/128 seconds)
      SKIP = 0                 !Enter number of lines to skip
      /INQUIRE,NUMLINES,LINES,FILE,TXT          !Finds number of lines
      READ = NUMLINES - SKIP !Calculates how many lines to read from data file
      *DEL,ACCEL,,NOPR !Deletes previous instances of ACCEL
      *DIM,ACCEL,TABLE,READ - 1,2 !Create a table for xy acceleration data
      *TREAD,ACCEL,FILE,TXT,,SKIP !Read data from FILE.txt into ACCEL table
      ACEL,,,9.81 !Gravity
      ANTYPE,TRANS !Transient analysis
      TRNOPT,FULL !Full method
      TIMINT,ON,STRUC !Transient effects (inertia/mass) ON for structural DOFs
      KBC,1 !Stepped loading for transient analysis
      OUTRES,ALL,1 !Output everything
      OUTPR,BASIC,ALL, !Basic solution print
      NT=READ !Number of data points
      NSUBST,1,,,1
      *do,i,1,NT !Running from 1 to NT all data points
      TIME,i*DT!Calculate time vector by DT
      CMSEL,S,COLUMNS!Select column component
      CMSEL,A,FLOORS!Select floor component (in other words all components of my model)
      NSEL,S,LOC,Z,0!Select all nodes at z = 0 to apply acceleration to
      D,ALL,ACCX,ACCEL(1,i)!Apply x acceleration
      D,ALL,ACCY,ACCEL(2,i)!Apply y acceleration
      ALLSEL!Select all nodes to complete solution
      SOLVE
      *enddo
    • Steve1995
      Hey Louis, did you solve the problem?
      I have the same problem now: i have a temperature dependig on the time and also the gravity in y-direction. My model only solves the effect of the gravity before the first temperature step and after that, it doenst change. Do you know, how i can solve this or can you tell me how you did it?
      Hope you see this,
      Thank you
    • asder
      @louis2222 , you solve it ??
    • asder
      FINISH
      /CONFIG,NRES,100000
      /PREP7
      DAMPRATIO=0.05000
      *SET,NT,2400
      *SET,DT,0.02
      *DIM,AC,,NT
      *VREAD,AC(1),seismic_record,TXT
      (F8.5)
      /SOLU
      ANTYPE,TRANS
      TRNOPT,FULL
      *DO,I,1,2400
      ACEL,AC(I),0,0
      TIME,(I)*0.02
      OUTRES,ALL,ALL
      SOLVE
      *ENDDO
      FINISH
      this code will help you
    • asder
      you mat use
      /SOLU
      DELTIM,0.02
      ANTYPE,TRANS
      TRNOPT,full
      AUTOTS,ON
      NSEL,S,LOC,Z,-38,375
      CM,NUPP,NODE
      OUTRES,ALL,ALL
      TIMINT,ON
      TIME,0.02
      ACEL,,,9.8
      D,ALL,ACCX,0.035672
      ALLSEL
      SOLVE
      TIME,0.04
      ACEL,,,9.8
      D,ALL,ACCX,0.009702
      ALLSEL
      SOLVE
      TIME,0.06
      ACEL,,,9.8
      D,ALL,ACCX,0.041944
      ALLSEL
      SOLVE
      TIME,0.08
      ACEL,,,9.8
      D,ALL,ACCX,0.04284
      ALLSEL
      SOLVE
      TIME,0.1
      ACEL,,,9.8
      D,ALL,ACCX,0.0106526
      ALLSEL
      SOLVE
    • asder
      I would keep it more simple so no do loops. In this way you just apply the time variation of the load as a table (Workbench uses something like this in Str. Dyn.). You need also to split up the acceleration data file to x-direction filex and y -direction filey.txt. That is very easy though.
      DT=1/128
      DTM=1/1000
      /INQUIRE,NUMLINES,LINES,FILEX,TXT !Finds number of lines
      *DEL,ACCELX,,NOPR !Deletes previous instances of ACCEL
      *DIM,ACCELX,TABLE,READ - 1, !Create a table for x acceleration data
      *TREAD,ACCELX,FILEX,TXT,,SKIP !Read data from FILE.txt into ACCEL table
      /INQUIRE,NUMLINES,LINES,FILEY,TXT !Finds number of lines
      *DEL,ACCELY,,NOPR !Deletes previous instances of ACCELY
      *DIM,ACCELY,TABLE,READ - 1, !Create a table for x acceleration data
      *TREAD,ACCELY,FILEY,TXT,,SKIP !Read data from FILEY.txt into ACCEL table
      /SOLU
      D,ALL,ACCX,%ACCELX%!Apply x acceleration
      D,ALL,ACCY,%ACCELY%!Apply y acceleration
      DELTIM, DT, DTM, DT
Viewing 5 reply threads
