July 30, 2018 at 7:47 pm
trbritt
SubscriberI have a 3D model of a magnet design in a different software I need to switch over to ANSYS. I have an APDL macro which should convert the data and I have the data in a seperate text file, which is how it was exported by the other software. When I run it in APDL, it gives me '*VREAD cannot open file'. Any suggestions?
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2564
2068
1289
1106
459
