May 15, 2023 at 10:01 am
Vaibhav Dixit
Ansys EmployeeQ: How does the API service connect into the customer’s environment?
A : Connection is made directly between the Ansys control plane and the AWS Service via API call over HTTPS.Q: Is there a certificate handshake on API Service connection and/or is there encryption?
A: Communication between the Control Plane and AWS is protected by AWS Certificates as HTTPS is used.
- (0x8007052E): The user name or password is incorrect
- Some of the instance types are greyed out and cannot be selected.
- Ansys Gateway powered by AWS – Minimum Technical Skills
- ADConnector Installation Fails due to .NET
- Unable to install Service.
- About Multi-domain support
- What is the average time to set an HPC cluster up?
- How does metering work?
- How do I enable multiple screens in an RDP session?
- Virtual Desktop becomes the failed state and appears AWS issue
5242
3299
2469
