June 29, 2023 at 10:31 pm
minusunny
SubscriberHi, I am trying to simulate sub wavelength bandstructure using the example provided (https://www.lumerical.com/learn/video/swg-bandstructures/ ) in FDTD . In the parameter section of SWG_bandstructure.fsp / model , i can see apod_center, apod_width, how do i set these? Do i assume it as the center of grating length and assume a random width?
June 30, 2023 at 6:20 pm
Guilin Sun
Ansys EmployeeThose parameters are used to pick up certain signals. Usually you do not need to change them. If you want to change, please check this article https://optics.ansys.com/hc/en-us/articles/360034902473-Understanding-time-apodization-in-frequency-domain-monitors
to get more information.
As for the grating length, it is periodic, meanining infinitely long.
July 4, 2023 at 3:23 pm
minusunny
SubscriberThank you. Also i am trying to draw grating along a trapezoid structure. I am not sure how to write a script for that. I know how to define a polygon and draw a plane trapezoid and normal grating using for loop.Do you have any suggestion for scripting this structure. Does array provides an option to create this struture? How to vary the length along the array keeping other parameters same?
July 4, 2023 at 4:39 pm
Guilin Sun
Ansys EmployeeYes, you are right that using a loop and defining the polygongs with parameters are better way.
Please note that the forum is one-post-one-question, so please write a new post if you have questions different from the original one.
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7742
4502
2967
1449
1322
