Applicability of compressible liquid density method
    • Luigi0
      Hi,nI want to simulate acoustophoresis phenomena. Since the velocity of the fluid (water) is low and the dimension of the channel is in the range of millimiter range, the Re number is a low value so the flow is laminar. Since the propagation of pressure waves is needed, I need compressibility, so I enable the compressible liquid method. In the fluent guide I see that this method is used for high pressure applications, but is not my case.nIs it reasonable to apply this method in my problem?n
    • DrAmine
      Apply it. If you have some particular EOS for the liquid you can use it too but you need to implement it. n
    • Luigi0
      Thanks, and how can I implement an equation of state?n
    • DrAmine
      User Defined Real Gas Model (Advanced) or via DEFINE_PROPERTY (if and only if compressible liquid) https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/flu_udf/flu_udf_sec_define_property.html?q=compressible%20liquidn
Viewing 3 reply threads
  • The topic ‘Applicability of compressible liquid density method’ is closed to new replies.
