TAGGED: ansys-student, cfd-post, cfd-post-error, error, workbench
November 30, 2020 at 2:01 pm
Daniel_Zhai
SubscriberAs the picture below shows, I encountered an error called "Application failed to connect" while trying to open the results from my Ansys Student Workbench 2020 R1:
November 30, 2020 at 2:15 pmRob
Forum ModeratorIn CFD Post go to File - Read and hunt through the Workbench project folder to find the case & data files. However I think your problem is that the Solution isn't up to date so there isn't any data to display (lightning strike symbol in the WB workflow). nNovember 30, 2020 at 4:06 pmDaniel_Zhai
SubscriberIn CFD Post go to File - Read and hunt through the Workbench project folder to find the case & data files. However I think your problem is that the Solution isn't up to date so there isn't any data to display (lightning strike symbol in the WB workflow).https://forum.ansys.com/discussion/comment/98798#Comment_98798
The method to open the results does work well! That offers a way to kind of avoid the bug. However, the error still exists even if I re-ran the calculations and got a green tick for Solution in the WB.nDecember 1, 2020 at 11:41 amRob
Forum ModeratorCan you transfer the solution data to another Results block? It's possible the existing link has corrupted. I post process in Fluent so rarely use CFD Post. nViewing 3 reply threads- The topic ‘Application Failed to Connect Error while Opening Results from Workbench 2020 R1’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
