October 10, 2018 at 6:27 am
Silviya_Petkova
SubscriberDear All,
have you got any idea if I could utilize Pipe289 in a model of a pressure pipe with both closed ends. It is a PVC pipe with D=0,114m and L=10m. The pipe is fully filled with water, an initial static pressure is applied in some steps of the laboratory experiment. The pipe is mount on a shaking table and after applying axial dynamic load in form of an acceleration record, the dynamic pressure due to the dynamic excitation of the pipe's support is observed.
So, the crucial here is that the pipe's both ends are closed.
Any idea would be highly appreciated!
Thank you
October 10, 2018 at 1:07 pm
jpasquerell
Ansys EmployeeYes. ends are capped by default. see keyopt 6 which defaults to setting of 0.
2066
1279
1096
457
