March 7, 2022 at 9:12 am
wangx3
SubscriberDear all
After the earthquake RSA, we can get the acceleration on the nodes. Can we use the acceleration data to do the push over-analysis? Simply saying, would it be possible that the workbench to generate the equivalent inertial forces on each element node using the accelerations? After that, we can do the nonlinear structural analysis? thank you!
March 10, 2022 at 8:19 amAshish Khemka
You can use command objects to apply acceleration data to the elements. Please see if the following links help you:
Ansys Insight: How can I apply acceleration to a particular body? ÔÇö Ansys Learning Forum
CMACEL (ansys.com)
Regards Ashish Khemka
2564
2078
1291
1106
459
