Apply Intrinsic stress to circular shell element
    • Tanmay Konnur
      How do I apply compressive and tensile intrinsic stress (on separate occasions) to a circular shell element such that it is uniform across the circular shell element. I do not want a gradient. Is INISTATE command applicable in this case?
    • Bill Bulat
      Yes, INISTATE is the command to use. I found this old MAPDL input file (pasted below) in my examples directory that illustrates usage. In this example, INISTATE is applied to solid elements, but it works for shells as well. With layered shells, you can apply different initial stresses to individual layers.
      I forget whether or not this feature is natively exposed in Mechanical. If not, you'll need to use an APDL command object to implement it.
      fini
      /cle
      /vup,1,z
      /vie,1,1,1,1
      /pnu,mat,1
      /num,1
      /gra,full
      /sys,del *.png
      C******************************************************
      C*** PARAMETERS
      l=1000e-6
      w=100e-6
      t_Pd=5e-6
      t_Cu=5e-6
      E_Pd=110e9
      nu_Pd=0.39
      E_Cu=117e9
      nu_Cu=0.34
      sgma_Pd=1e6
      C*** GEOMETRY
      /prep7
      vsel,none
      bloc,,l,,w,,t_Cu
      vatt,2,2,2
      vsel,none
      bloc,,l,,w,t_Cu,t_Cu+t_Pd
      vatt,1,1,1
      numm,kp,1e-8,1e-8
      C*** ATTRIBUTES, MESH
      et,1,185,,2 ! PALLADIUM ATTRIBUTES
      mp,ex,1,E_Pd
      mp,nuxy,1,nu_Pd
      et,2,185,,2 ! COPPER ATTRIBUTES
      mp,ex,2,E_Cu
      mp,nuxy,2,nu_Cu
      alls ! MESH
      vplo
      vmes,all
      C*** BCs
      alls
      d,node(0,0,0),all
      d,node(0,w,0),ux
      d,node(0,w,0),uz
      d,node(0,0,t_Pd+t_Cu),ux
      C*** Pd INITIAL STRESS
      inistate,set,dtyp,,stre
      esel,s,mat,,1
      inistate,define,,,,,sgma_Pd,sgma_Pd,sgma_Pd
      fini
      C*** SOLVE
      alls
      /solu
      save
      solv
      fini
      C*** POST PROCESS
      /post1
      /pbc,u,1
      eplo
      /sho,png $eplo $/sho,close $/wait,2
      plns,u,z
      /sho,png $plns,u,z $/sho,close $/wait,2
      plns,s,x
      /sho,png $plns,s,x $/sho,close $/wait,2
      esel,s,mat,,1
      plns,s,x
      esel,s,mat,,2
      plns,s,x
