Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
apply motion for double rotor
    • ssaeidab
      I want to simulate in maxwell_2D a motor with the double rotor, inner rotor, and outer rotor. The rotors are united and I defined the band for inner rotor and which is a circle and I defined a band for the outer rotor and it is a disk. I choose 3000 rpm for both bands but it does not work and there is e error. when I separate two rotors it works bit I got two oggin torque.
      could you please help me with this?
      Thanks
    • Navya C
      Hi @Saeids
      From version 2020R1 onwards you can have two separate rotors - define two bands and have two motion setups.
      Please provide more screenshots related to your model and band setup for our better understanding.
      Any 3D images that explain your motor construction will help better interpret the model.
      Regards
      Navya
    • ssaeidab
      This is my motor model. It has two roto, inner rotor, and outer rotor. These two rotors are connected to each other in real. and they rotate at the same speed.
      So, I unite them, and then I consider two-band for them as follows. I unite the bands and consider them separate but I got an error. So, I decided to separate the rotors and considered two bands for them separately, I got results. But I got two Torque separately for the inner rotor and outer rotor. In reality, It should be one torque. Could you please help me with that.
      Also, How can I sum these two torque waveforms?
      Thanks.
    • ssaeidab
      Could you please help me with that?
      Thanks
    • ssaeidab
      Hi Also, these are the figures from the original paper that presented this motor. Based on the figure for this I should have one torque because I define rotors separately I get two torque.
    • Navya C
      Hi @Saeids
      The way you got the result is correct (Not sure about the values though).
      You will get two torques. you just need to add them and plot as shown below to get the resultant torque.
      Write the expression as shown below after you select Resulsts>Rectangualr plot
      Regards
      Navya
    • ssaeidab
      Thank you so much for your help.
Viewing 6 reply threads
