May 17, 2022 at 2:07 pm
Shahbaz_khan
SubscriberHi, I want to apply multilinear isotropic hardening model of plasticity in material define properties. I have inserted the plastic strain vs True stress values that I got from tensile testing. After defining material properties, when I open the Explicit Dynamcis(AutoDyne) in Ansys Workbench, then I got the following error
May 18, 2022 at 10:56 amAkshay Maniyar
As an Ansys employee we are not allowed to download any attachment from forum. Can you insert image so that it will be visible and we can help you as early as possible.
Thanks Amaniyar
May 20, 2022 at 6:54 amMay 20, 2022 at 6:55 amMay 20, 2022 at 2:56 pmAkshay Maniyar
You can define up to 10 stress strain pairs using this model in explicit dynamics systems. Because of which you are getting the above error. It is also documented in Ansys help at this link.
Thanks Amaniyar
Viewing 4 reply threads- You must be logged in to reply to this topic.
- A solver pivot warning or error has been detected
8740
4658
3151
1678
1452
