July 25, 2019 at 2:25 pm
imohamma
SubscriberHi all,
For what I'm doing I have to apply a time dependent current density as a boundary condition. Looking through the documentation I'm unsure if :
1- Ansys supports such boundary conditions
2-If it does, where in the program I can implement it
To my understanding , I need to use either a UDF or expressions to write out the time-dependent current density. I'm using the MHD module, with the electric potential method. There is an option under the conducting wall boundary where I can set the current density, however it only takes in a constant. I went through the help documentation, including the theory section, and wasn't able to find an answer. Any insight is appreciated!
Best,
Ibrahim
- Maxwell, HFSS or Q3D?
- Error
2656
2120
1349
1118
461
