Discovery Import
Discovery Import
Applying ambient air condition for manifold simulation
    • nagarajan.dharanibalan
      Dear All,
      Could anyone support on the procedure to apply environment of air for a thermal simulation of exhaust manifold?
      1. How to define that exhaust manifold is in air media, properties of air like temperature, density, pressure etc.,
      2. I have already created selection set of external surface of manifold
      #air media, #component environment definition #air properties
    • Naresh Patre
      Hello Nagarajan D
      You will have to create a fluid domain around the manifold and assign Air material for the fluid volume. You will have to use Conjugate Heat Transfer template for your analysis. Please check out some Fluid-Solid Heat Transfer (CHT) application examples from below link:
      Discovery AIM: Application Examples: Fluid-Solid Heat Transfer (CHT)
