Applying pressure on the limited area
    • userek
      Hello.
      I'm struggling a problem in Static Model.
      I created a model in a 'Geometry' - a rectangle. Then it have been filled and divided into 3 because I have to load it later on a part. In the ACP (Pre) Model is fine (it is divided and I see 3 parts) but in the next step , which is Static Structural, there is no division - there is just one big face instead of 3...
      I tried also something like this: https://www.researchgate.net/post/How_can_you_apply_loads_for_a_limited_area_given_the_entire_surface_of_a_model_in_ANSYS but without reason.
      How can I apply that pressure to the area? I'm using Workbench 2019 R3 (student version).
      Thanks in advance!
    • Aniket
      You can select the nodes, (manually or using named selection based on a worksheet) and then apply nodal pressure.
