July 1, 2020 at 3:03 am
mi264
SubscriberHello all,
I have designed a PMSM in ansys maxwell. I want to apply skew in rotor and observe the change of characteristics. My question is:
how can I apply skew in the rotor or magnet in the maxwell?
Thank you
July 2, 2020 at 7:25 am
July 2, 2020 at 4:51 pm
mi264
SubscriberThank you Navya
January 21, 2021 at 4:06 pm
NathanEmery1
SubscriberHi Navya, nnThank you for this post, I have also been using the Skew model for a PMSM in Maxwell. nIs there a way to apply a V-skew technique where the segment settings are not distributed from + to - degrees. nFor example if I want to apply a V-skew with +2.5 deg, 0 deg and +2.5 deg segments is this possible using the ansys Skew settings? nnPlease let me know. nThank you, nNathann
January 31, 2021 at 11:52 am
Navya C
Your question is being answered in the below post.
https://forum.ansys.com/discussion/comment/104550#Comment_104550
- Maxwell, HFSS or Q3D?
- Error
3862
2631
1859
1254
600
