Applying Same CFD Post Processing to Different Files
    • amr92
      I have several internal flow simulations with different conditions. I would like to apply the same post processing to all of them without having to set it individually (planes, contours, graphs, etc). Is there a fast way to do so?
      Have a look in the manual for the State file & combine that with Figures and a Report if you're using CFD Post.
      If you're using Fluent and it's the same mesh you can read data back onto the original case, or you can drag & drop the planes/contours from one session to another in 2019.
