December 4, 2019 at 11:56 am
Gijoys4v
SubscriberPlease help!
I applied temperature load (from 1000K to 500K) on a geometry and obtained the strain. Next I want to apply the temperature load (500K to 200K) on the same geometry in which the strain obtained previously should be there. How can I do this ansys? When I tried to couple the first solution to the next structural analysis; it is not working. It shows that the next structural analysis became the submodel of the previous one. In short; I want to apply a residual stress in the model.
December 4, 2019 at 8:52 pm
SubscriberIs the only thermal load Temperature? Is it applied to the entire body? In that case, the temperature is uniform over the whole body and you can apply that load directly into a Static Structural model using Thermal Condition and there is no need for a Thermal model.
If you have to solve for the non-uniform distribution of temperature due to other boundary conditions, then you need the linked analysis systems. In the Thermal analysis that changed the temperature from 1000K to 500K, under Analysis Settings, where it says Number Of Steps 1, make it 2.Then in the Temperature load, there will be a second row where you can type 200K for step 2. Create 2 steps in the Static Structural system. On the Imported Body Temperature, make the settings shown below.
December 5, 2019 at 1:50 am
Gijoys4v
SubscriberThank you for your reply. Iam applying only thermal load and your reply helped me. But a problem arises when I tried the same in a new geometry. The situation is as follows:
I have two plates bonded each other which is at a temperature of 1000K. Then I have to cool the plates to a temperature to 500K. So a strain arises in these plates. Next at temperature 500K, I have to bond two more plates over the previous two and then I have to cool all these to 200K. So when I followed the method you said earlier upto 500K(when there only two plates) there was no problems. But when I added the two plates, ansys says the solution has to be cleared for adding the extra plates. How can I add those two plates at 500K on the two plates without clearing the solution (means I need the residual strain on the first two plate, when I am adding the two new plates on top of those previous) -
December 5, 2019 at 4:12 am
SubscriberI have two plates of the same material made to have the same length at 1000 K.
In Step 1, the right part stays at 1000 K, while the left part is cooled to 500 K.
In Step 2, the bonded contact, which was Dead during step 1 is made Alive in step 2.
In Step 3, the temperature of the right part is cooled to 500 K and the strain bends the part.
You can build this out in subsequent steps to make alive another bond to another layer and cool it to 200 K.
December 5, 2019 at 5:13 am
Gijoys4v
SubscriberThank you, your timely reply giving me a lot of help and relaxation. But I don't know how to make a part dead and alive in steps. From where I can find that option to make a part dead or alive?
December 5, 2019 at 12:32 pm
December 5, 2019 at 2:13 pm
Gijoys4v
SubscriberThank you for your reply. very sad to inform you that I was trying to do the analysis with Ansys 18.1 which is not having this provision. I will try Ansys 19 and inform the progress and contact you soon.
December 5, 2019 at 2:14 pm
Gijoys4v
Subscriberor else do you know the command for this?
December 7, 2019 at 9:35 am
Gijoys4v
SubscriberHallo peteroznewman,
Now I have Ansys 19. In the above explained example by you. How you maintained one part at 1000K and the other cooling to 500K. Expecting your reply. Thank you
December 7, 2019 at 9:46 am
Gijoys4v
SubscriberAlso whether we can do the same example like this. while making the contact alive whether we can cool the second part to 500K. whether it is required that the making the contact alive should be made in a single step(means whether a step should be separetely assigned for making the contact alive)
December 7, 2019 at 12:23 pm
SubscriberThe Thermal Condition load in Static Structural allows me to assign a Temperature load to a body. In this case, I have two bodies and the each has an independent Temperature load on the body. This is a 3-step analysis and the Environment temperature, which sets the temperature of all bodies at the start of the simulation, is set to 1000K. In step 1, I change the Temperature of one of the bodies to 500K and leave the temperature in the other Temperature load at 1000K.
In step 2, the contact comes alive. That means a hot body is being bonded to a cool body.
In step 3, the temperature of the hot body is changed to 500K and the cool body remains at 500K. This is when the strain develops that bends the beams.
December 8, 2019 at 5:37 am
Gijoys4v
Subscriberthank you for your valuable and timely reply. it really helped me a lot
December 8, 2019 at 5:42 am
December 8, 2019 at 3:32 pm
SubscriberPlease learn how to make a screen snapshot that does not have a huge white border.
You can right mouse click on a result and Export the nodal data to a CSV file, then perform the volume average in Excel or matlab.
December 9, 2019 at 1:24 pm
Gijoys4v
SubscriberThank you.... I will do
December 9, 2019 at 1:26 pm
Gijoys4v
SubscriberIs there any provision in ansys sothat we can make a fixed support (or other similar supports) active after a particular load step(say after 2 steps)?
December 9, 2019 at 1:43 pm
SubscriberNot Fixed Support, but Displacement can be set to Deactivate, or Activate by load step. In the Tabular data panel where it shows the displacement setting, which can be 0, you right mouse click on a row and select Deactivate. Contact objects can be set to activate or deactivate by load step also.
December 12, 2019 at 4:55 am
Gijoys4v
SubscriberThank you, it worked
December 13, 2019 at 10:37 am
Gijoys4v
Subscriberwhich solution will be correct? with large feflection ON? or large deflection OFF? in the analysis settings
December 13, 2019 at 12:26 pm
Gijoys4v
Subscriberwhile I solved a structural problem using workbench in 1step(analysis setting 1 step is given with 10 substep), I could obtain the stress at each substep. But when I solved the same problem in 2 time step(in the 1st time step I made one side of the beam fixed and the next time step a displacement is given), in the second time step I can find only the final answer, the substep I given havent seen. Please help me to resolve the problem
December 13, 2019 at 12:27 pm
Gijoys4v
Subscriberfor finding ut the reaction force after structural analysis in workbench, I have seen different location methods in the details window like boundary condition, beam , spring, surface etc. which one I have to choose. how can I understand which one I have to choose for a particular problem. what is the meaning of each one?. Please help!!!!
December 13, 2019 at 3:49 pm
December 13, 2019 at 6:52 pm
Subscribera
December 13, 2019 at 6:54 pm
December 13, 2019 at 8:06 pm
SubscriberYour last question was answered in this post.
Can you see how you can waste our time if you are asking the same question in more than one discussion?
December 14, 2019 at 4:29 am
Gijoys4v
Subscribersorry
December 14, 2019 at 4:42 pm
3311
2471
