Tagged: ansys-aqwa, ansys-workbench, aqwa, aqwa-errors
September 15, 2022 at 4:13 pm
September 16, 2022 at 3:08 pm
Yu Bi
Ansys EmployeeHi, could you first try Solve Hydrostatic Only to see if there is any setting problem with the model?
September 16, 2022 at 6:20 pm
Aakash Gupta
SubscriberYes, I am able to solve Hydrostatic only simulation.
September 20, 2022 at 2:37 pm
Yu Bi
Ansys EmployeeHi, I am afraid it is hard to track the real reason for this error with few amount of information. Can you give more info about your project? Like the Ansys version you use, the size of the project, how many panels your model has, and the residual space of your disk/C: drives, did you successfully run the Aqwa project in the same file location before on your PC? Is there an ANALYSIS.VAC file in your solver file directory when this error occurs and what the file size? Is there any other error message in the ANALYSIS.LIS file and ANALYSIS.MES file?
- Workbench error
- Workbench not opening
- License Error
2726
2156
1359
1150
462
