November 22, 2017 at 2:14 pm
danirizziero
SubscriberHi there! I'm doing a lot of simulations with Aqwa and I've a problem exporting data (in order to do diagrams). The problem is that the CSV file produced by Aqwa uses ',' as separator between the values. These values are not integer numbers!! So when I try to open the CSV file with Excel or similar the result is messed up (please see example below), because the integer part and the fractional part of each number are divided into 2 different data entries in the XLSX Excel file.
[Example]
Original Data Entries:
12,234
84938
65,98
CSV FILE:
12,234,84938,65,98...
Is there any way to make Aqwa use a different separator between the values? I think that might solve the problem.
Thanks in advance!!
Daniele
2706
2142
1357
1144
462
