May 10, 2022 at 10:12 pm
riyanto.r
SubscriberHi all,
Is it possible to automatically extract Position, Velocity and Acceleration in custom specified point instead of CoG? I read the AqwaReader Manual and see nothing related to that.
May 27, 2022 at 11:07 amIngrid Machecler
Ansys EmployeeGood morning You would need to add a connection point under your geometry. In its detail panel, switch to "YES" the "include in Results" option.
In the Aqwa editor, you can select the location point corresponding to your results and export the results at CSV: this can be at the COG or the connection point you have just defined.
Likewise, AqwaReader will also list your user defined point when you query for Aqwa Graphical results.
I hope this helps.
Kind regards Ingrid
3862
2629
1859
1252
600
