Ansys Products
Ansys Products
Aqwa-Geometry update failed
    • Greg Ioannou
      As im changing the geometry at Spaceclaim and try to update it,it appears the above error:
      and then that:
      Why does that happen?It happened today...for first time
    • Yu Bi
      Hi, could you describe a bit more about how this error message happened? Was the geometry in Aqwa initially OK and after you updated the geometry in the SpaceClaqim, it went wrong? If so, what changes did you make? In the project schematic, can you try to link the geometry cell to a new hydrodynamic diffraction and see if the same error appears?
    • Greg Ioannou
      I followed the right steps and it appeared that message sometimes.Now,it is ok.In the project schematic ,after i changed the geometry at Spaceclaim,i updated the model...and i didnt understand the error.Thats why i posted it here.Now,everything is ok,despite i didnt understand how this error problem appeared and fixed.
      Thank you Yu Bi!!
    • Yu Bi
      Hi, Greg, good to hear the problem was solved. The problem should be related to different software package communication. Like networks, the software also could work abnormally occasionally.
Viewing 3 reply threads
