July 31, 2020 at 2:45 pm
Akismet
SubscriberCan some explain what is Archimedes principles?
August 18, 2020 at 3:37 pm
Ansys EmployeeA body will displace it's own volume when immersed in a fluid. So, if your bath is full and you get in you'll spill your own (body) volume on the floor. nAs a bonus,Eureka! is Ancient Greek for where 's my towel?. One of the above may not be entirely true... :) -
August 19, 2020 at 9:18 am
Ansys EmployeeRead the Wiki page on Archimedes, there are several fascinating bits of technology that he's associated with. n -
August 20, 2020 at 3:37 pm
mcoderon
Ansys EmployeeCiting from our Ansys Innovation Courses Archimedes ' Principle states that the pressure force acting on a body immersed in a static fluid equals the weight of the fluid it displaces You can take a look at this course on Fluid Statics for a better explanation of this principle. In particular you may be interested into the second lesson of the course. The description should give a complete overview of the Principle.nn -
September 2, 2020 at 11:50 am
chad.capote
SubscriberArchimedes' principle states that-any a body completely or partially submerged in a fluid(gas or liquid) at rest is acted upon by an upward, or buoyant, force, the magnitude of which is equal to the weight of the fluid displaced by the body. This means that suppose a brick is thrown in the water, the brick initially sinks and loses a part of its weight, which is replaced by the buoyant force acting from below that helps keep the brick afloat. Archimedes' principle and density explain to us why ice floats in water.
- What is the difference between internal and external flows?
- How do you define specific gravity? What is its significance???
- Why is it much easier to roll a log than drag a wood cube with the same mass?
- The level of water inside the straw was higher than the level of water in the beaker
- What is the surface tension of a fluid?
- How to gain research experience?
- Whats the difference between sensible heat and latent heat?
- Cell Counting?
- Why does the total sum of forces acting on a system always have to be equal to zero?
- Why ice floats on water
2706
2142
1357
1144
462
