Archiving a file
    • rahul5191
      I have done a project work and i want to share that file to someone (archive), but i dont want anybody else to use that file to re run in another system by modifying the values.
      Is it possible to archive in such a way that he/she can only view that but can never edit or rerun it
    • Keyur Kanade
      In workbench you can archive file.
      Go to file - archive. It will save *.wbpz file which you can share with others. Then user also need to retrieve it using file - retrieve option. if using 2020R1 then you can directly open it.
      Keyur
    • peteroznewman
      To create a file that has results in it, but cannot be changed, right click on the result and Export > ANSYS Viewer File (AVZ)
      Send the .avz file to anyone. They can download the free ANSYS Viewer, and open the .avz file.
      They can look at the model and results, but can't change anything.
      You can also Export the Mesh and Geometry.
    • rahul5191
      nw this really helpd... thankyou ?
Viewing 3 reply threads
